Maintain Slam level for your cya FC/CYA Levels no more no less.Great, thank you. I'll add a little more Chlroine to move the FC up from 15.5 back towards 20?
Pools consume chlorine on their own 2-4ppm per day so if you lost 4ppm per day for two days that would get you from 17 down to 9. That’s going to happen all summer so probably not related to any dilution from rain.So we had a ton of rain this weekend (around 3/4 inch - maybe even an inch) so I left the pool be for a couple of days. It's looking very clear but the FC has some down from around 17 to 9 (I guess dilution played a part?). The pool is looking very clear and the 'dust' that I was brushing off the floor has largely gone. Do I let the FC settle back to normal levels and turn on the salt cell to kepe it constant, balance out the chemicals etc and return to maintenance mode, or do I continue with the slam process (e.g. test the overnight loss tonight)?
OCLT: lost 1.5ppm (3 drops) overnight. So v close. Pool also looking very clear. Gave it a good brush again today, we did have a little of what I think is white mold gathering on top (heavy rain raised the pool level and the skimmer wasn’t very effective for a day or so), so I backwashed, brushed it down, backwashed again this morning….Understood - 2 more gallons just applied. Will do the OCLT tonight. Thank you!
