- Jun 24, 2021
- 15,931
- Vinyl
- CircuPool RJ-60 Plus
Great Job on the kit!!!
All your numbers look good, except the CYA is high. With CYA of 90, you will need to keep your FC between 10-12 to sanitize the pool. Your CYA is high due to puck use. I would not, at this point, use pucks or any dry chlorinating product.
You need to use this tool and chlorinate based on your CYA. Link-->FC/CYA Levels
I would do this test tonight to confirm you don't have algae (even if you don't see it). Link-->Overnight Chlorine Loss Test
You might think about replacing 30% of your pool water to reduce CYA to 60, this will reduce the chlorine requirement.
