- Sep 3, 2018
- 1,340
- Pentair Intellichlor IC-40
For some reason our chlorine levels have been going down quick, which is probably because we're swimming more and it's getting hotter. Last night I checked and it was 2 so I upped the percent to 60%. As I was checking the pH I decided to use the block tester to see if levels were up and worth testing again. It showed the brightest yellow possible so I tested. It was only at a 3. I get that the block test isn't exact but shouldn't it be closer than that? Am I missing something else? Does that mean my pH isn't correct either? What percentage should I expect to keep my SWG at for the summer? We run the pump from 11pm-11am.
