Second year pool owner and this is the first time I'm having issues with the Chlorine levels.
I shocked the pool with non chlorine shock about 5 days ago due to high combined chlorine levels. At this test I think the reading was around 2.4.
I waited a day and then tested again and for some reason the combined chlorine went even higher. Don't recall the number.
Yesterday afternoon I decided to go to my local pool store and get the water tested. They had me add 4 lbs and 3 oz of CAL-SHOCK due to still a high combined chlorine level. I added yesterday evening and let the pump run all night.
Took water back to pool store and now the readings seem worse.
FC = .89
TC = 9.41
CC = 8.52
PH = 8.2 - I just added acid and re-tested and I'm now at 7.3
ALK = 90
CYA = 47
Iron = .1
PHSPHATE = 350
Odd thing is that the pool doesn't really smell and is crystal clear. I'm reading that the non-chlorine shock can give false TC readings. Is that true and would it cause these fals high reading for days after?
I'd appreciate any feedback on this as I'm puzzled at this point.
FC = .89
TC = 9.41
CC = 8.52
ALK = 90
CYA = 47
Iron = .1
PHSPHATE = 350
