Chlorine Generator Requires Pump to Run at 2500+ RPM
Based on the numbers, you should be triggering flow at about 1,500 to 1,700 RPM.
Maybe there is an issue with the suction or maybe a clogged impeller.
The performance is not bad enough to really worry about, but it seems lower than expected.
Maybe the flow switch is not working accurately?
