Longtime listener, first time caller here.
Going out of town on vacation for 1.5 weeks and trying to figure out how often to have someone check in on the pool, and whether to bother having them check the FC or just add chlorine. Specs:
Above ground
24' round
14,500 gallons
82-85 F
CYA: 40
pH: 7.5
TA: 75
(Yes, I use Taylor reagents for all testing! And the premium Pool Math Android app for tracking
Pretty much the only treatment it needs is regular doses of liquid chlorine and occasional aeration to prop up the pH. (For reasons I don't understand, it tends to drift down even though everything else is balanced, but that's a different question for a different day.)
So the question is, all other things being equal (temp, sunlight, pool volume, other chemicals, etc.) does the FC level drop by a more or less constant AMOUNT per day, or at a relatively predictable RATE per day? With current conditions (hot & sunny) it drops 2-3 ppm/day regardless of the target level, but my data collection hasn't been stringent enough to do a proper analysis of amount vs. rate ...
Another option is to hack up a few 3" trichlor pucks and stick them in the Pool Frog that came with the pool but has been unused for years - I've done this before but never for such a long stretch of time.
Thanks in advance!
Above ground
24' round
14,500 gallons
82-85 F
CYA: 40
pH: 7.5
TA: 75
Thanks in advance!
