Sure, vac. Monitor the psi on the filtergerks9800 said:I will do that! Should I go ahead and vacuum?
That is fine. .5 CC is okay. No need to shockgerks9800 said:Can anyone tell me what this means? FC held overnight and CC is down to .5 and has been since yesterday morning. I just took FC reading again (about 3 1/2 hrs since last one) and it is at 9.5 and CC at .5. Is that ok? Should I bring FC back to 12 or because it held overnight it's ok? I know I want FC to hold, CC to be under 1 and clear water...just wanted to ask to make sure I should add bleach again. Should I do an overnight test again as well?
Butterfly said:gerks9800 said:Can anyone tell me what this means? FC held overnight and CC is down to .5 and has been since yesterday morning. I just took FC reading again (about 3 1/2 hrs since last one) and it is at 9.5 and CC at .5. Is that ok? Should I bring FC back to 12 or because it held overnight it's ok? I know I want FC to hold, CC to be under 1 and clear water...just wanted to ask to make sure I should add bleach again. Should I do an overnight test again as well?
That is fine. .5 CC is okay. No need to shock![]()
CC can bouce from .5 to zero and back and forth, but that is common.
The pool is clear, right? See red lines in my sig
Your FC should not be allowed to drop below 3 ppm! Normal range for your FC is 3-7 ppm (using 40 ppm cya from poolcalculator.com). Hopefully you are still algae free?gerks9800 said:SO I just need to add chlorine to get back up to a 3-4 of FC, right?
Just keep a close eye on ph and when it gets to 7.8, lower it down to 7.2...this will slowly lower TA over time.gerks9800 said:ince PH is good, I don't worry about the Alkalinity being a little on the high side?
