duraleigh said:tr,
Not to worry. You can manage with that 60 CYA for the rest of the summer.....it's high but it's not unacceptable. You'll do fine.
1. If your water is clear, I would not shock right away....you may not need to. It will depend on your CC test results to determine the need to shock. Can you do the CC's test?
2. If you do need to, you can use Jason's calculator (in my sig info) to figure how much you will need.....you will need you need almost 4 gallons of 12% chlorine
3. Assuming you do shock, it is not a one-time event. Rather, it is a process that can take a few days. Read How to Shock up in Pool School
Post back with more questions. You have progressed tremendously and are getting nearer to taking charge of your pool.
Thanks. I spoke to the local chem place, and they recommended 5 gallons of liquid shock, which is what I went ahead and applied. I do have the tester for CC and FC, but the level on my tester only goes up to 5 ppm.
I read the shock process document in Pool School. It looks like a drop of 1 ppm or more overnight requires another shock treatment, but my kit is likely useless for this (given that I'm sure my FC is far above 5 now and I have no way of determining a 1 ppm drop overnight).
One thing is for sure -- no more trichlor or dichlor until the stabilizer readings go down throughout the summer. I'm on 100% liquid chlorine now!
