Happy summer! After SLAM, should I expect my Free Chlorine to decrease rapidly in the hot sun (its 90 degrees/sunny here today)? Long story short, I brought my chlorine to 22 after the sun went down last night and only needed to add 1lb cal hypo throughout night to maintain 22 (at 10 pm). I was actually up all night checking the level every 1-2 hours. Right before the sun came up I checked it and the level held with no CC. I checked it at 9am and it dropped to 20. 12 pm 18. Should I be worried about this drop or is it to be expected?
these were my readings at 6am
CYA 50
TC 22
CC 0
PH 7.4
TA 80
I have another question as well. Im using cal hypo. It increases my PH. Is this temporary? I adjusted my ph w muriatic acid an hour after the initial SLAM because the PH was so high. Should I have done that? Is my PH going to bottom out after the chlorine burns off? My TA increased as well but I didnt add baking soda as it was 55 before the chlorine was added. I appreciate any input. Also, The reason I brought the chlorine level to 22 is because I never trust my eye with the CYA reading and would rather go alittle over than under and have to repeat the process.
CYA 50
TC 22
CC 0
PH 7.4
TA 80
