Chlorine 12 ppm, PH 7.5, No Reading For CYA?
Jul 29, 2014
20
West Palm Beach
Hi everyone,
I tested the CYA level in my inground pool last night and the CYA level in the Taylor testing kit that I use did not even get close to the 100 level - the black dot disappeared just a few drops in and a LONG way off the first marker, which is "100" and then goes up to "30".
What does that mean? Too much CYA?
I had none a week ago and put in 4 lbs about 3 days ago.
Any help is appreciated.
That means your cya is way way way above 100 PPM and that you need to replace water to lower it.
How did you get the reading before that said you did not have any cya?
