Hi,
Problem arises when I run pump continuously (start at 8am and check next morning around 6:30am) that eventually the chlorine output cuts off and chlorinator says high salt. Considering I am near the bottom of the range of salt level, was wondering why this would be happening?
My only conclusion is that possibly the cell is about to die?
When you have a range of 3000-8000 is it better to have more salt? Does more salt = able to use lower setting on chlorinator/generate more chlorine?
Any help appreciated. Thanks
- I have a viron v35 chlorinator.
- Pool size of approximately 48/50000 litres.
- Chlorine output can be set from 0 to 8.
- Salt lever for chlorinator should be in range 3000-8000.
- Have tested salt levels many times (> 10 times) at various pool shops and readings all come back around 3500.
