So, I’ve been wondering since I powered up my pool, what setting is recommended/should I use for my chlorinator when running in spa mode vs. in standard pool mode.
I have an infinity spa that regularly overflows into my pool. I also have the ability with my EasyTouch 4 and ScreenLogic2 to set different chlorinator percentages for both the pool and spa. Obviously when in spa mode, there is no longer any overflow. So I am wondering, what is the general rule/standard for setting your chlorinator output when in spa mode? Should I just set it to the same as my pool? Higher? Lower? I have tried researching online and am not really finding any info. What are you folks with similar setups doing?
Thanks!
Sean
Thanks!
Sean
