Well, even if you ran your SWG everyday, for 8 hours, at 60% you've only used 1752 hours per year, so that rules that out (at two years, that's well under your IC's 10000 hr expected life). It doesn't rule out that the cell might be defective in some way, and has reached it's end-of-life for some other reason, but we don't need to go there until you rule out the other chemical possibilities, including build up on your cell's internal plates.
BTW, a pool store, and/or a pool guy can help you achieve what looks to be a healthy pool (clear water), but that doesn't mean it's actually sanitized. They can help you achieve that, too, but it is usually at the expense of adding chemicals that will eventually backfire, or necessitate a water exchange, or even damage your plaster.
It might
seem like you were better off with a pool guy, but it likely only
seems that way. If you continue to explore this site, and the TFP way of managing your pool water, and embrace its methods, you'll save money, your water will be cleaner and healthier, and your pool will last longer. That might
seem to good to be true, but it only
seems that way!
The experts here will have your dilemma sorted out for you in short order. Trust their advice...
