- May 21, 2020
- 9
- Fiberglass
- Hayward Turbo Cell (T-CELL-5)
My chlorinator has suddenly started turning off with no flow error. I was running the VSP at 1800 RPM. When it primes in the morning at full speed the flow switch is fine. I bumped the daily running speed up to 2000 RPM and was getting flow again. Two days later, getting no flow at 2000 RPM. Bumping it up, I get flow again. Is this a failing switch? Not sure why it would require progressively higher pump speed to work. Cell, pump basket and filter are clean. Thank you.
