- Mar 18, 2017
- 21
- Vinyl
- Hayward Aqua Rite (T-3)
Received tf-100 kit today and first results assuming I did everything correctly.
C = 0
pH = 7.5
TA = 120 (turned a light shade of red at 110 then darkest it went was at 120)
CYA = 0
I've filled the pool to about the top of the skimmers so I can manually vacuum to waste when my hose arrives today. There's a fair amount of dirt at the bottom so I assume I should by pass the filter. Should I recheck levels after vacuuming water down to normal level or won't it mater. Filter had been running for about 4 hrs when I took sample so water should have been well mixed.
Thanks
Phil
C = 0
pH = 7.5
CYA = 0
Thanks
Phil
