I just don’t test for calcium. As I understood it was pretty stable & I thought I was within “normal”. Should I bring it down? Or slam in case this is algae? My ch & ph have been fine only my TA bit high; so I’ve added ph minus granules, roughly every 4 days, brining it down from pH 7.8 to pH 7.2I haven’t added any calcium, that’s just what’s in my water. Yes I have an ASHP at 30.
Oh no... That is not what you want to use at all. That's got thickeners that are going to make trouble for your water and whatever the anti-limescale stuff is probably isn't going to be good for your water either.Slammed
Does you filter pressure rise that quickly? Only backwash after your filter has increased by 25% from the "clean" pressure. Sand filters actually work better if they are a little dirty.My sand filter is 2 or 3 months old, I back wash it between daily or every other day.
Pressure drops when I use the intex vac, pool pump seller (fab) said backwash. Sorts it every time.If you have used that thick bleach before, that might be part of your cloudiness issue.
