Looking for recommendations on a good set up for beginners.
What chemicals would you order? What pump would you use?
Pool is an coleman above ground 16ft round pool and holds 5,000 gallons of water.
Will be Looking at either Amazon or home depot for needed chemicals.
I so far am looking at chlorine tablets and floater. Unsure of Size and amount as well as frequency of adding to pool? Or if i should use any other chemicals? Also once set up at what point can you start using the pool? Days after chemicals and filter runs or next day?
Another helpful tip I need is what pump to get. This is my first pool and I have really no experience.
Planning to set up in the next day or so.
Thank you for all input.
