(First Post)
I have been getting a lot of advice from this forum over the past 2 years since I bought my first home with a pool. You all have helped me a lot and I thank you very much. But now I have a problem that I just can’t figure out. Here is a quick rundown of what has happened. This past winter I covered my pool and had the pump running 4 hours a day. I would brush it once in awhile and vacuum it about every other week. Everything was fine. Then I went out of town for about 3 weeks and at some point the chlorine generator stopped working. When I got home I had a pool full of mustard algae. I Replaced the chlorine generator, got rid of the algae, cleaned all the pool equipment, and my pool looks great. Now here is my problem. Two weeks ago the alkalinity was over 300. I used several gallons of muriatic acid to get it down to 120. That also lowered the PH to 6.8. Then I added 10lbs of soda ash. That brought my ph up to 7.4 and the alkalinity back up to 280. I never had a problem before the algae attacked and never had issues balancing the chemicals. What happened and how do I lower alkalinity and raise the ph?
