Begin Rant (I really hate having to empty out my pool and waste water due to the fact that my original pool person used Trichlor for the last 6 years) End Rant
Now,
After finally getting my CYA down, the following is what I measured.
CYA = 35ish, so I'm rounding up to 40
Chlorine = Non - Existent
Ph = 7.8 (initially) - 7.2 (After adding Muriatic Acid, waiting, and remeasuring)
Calcium = 350
ALK = 230
Due to lack of Chlorine, I'm currently in the process of SLAM. Pool math says I should put in 409 oz. I've already dumped in 1 gallon, and will be doing the 2+ more by the end of the evening. I know that my Calcium is at the top of the recommended range. Should I work on dropping that down? Finally, shouldn't I be concerned with the ALK at 230? I know that it impacts Ph levels. Thanks for all the information!
Now,
Calcium = 350
ALK = 230
