We're filling our above ground pool right now, and I went out there to check its progress. I decided to put the thermometer back in, and immediately stepped into a rather extensive puddle around the edge of the pool.
"OH NOES!!!" I thought. " A LEAK!!! " And right where it's hard to see/fix, under the steps. I peered around, hoping I could find the leak, then noticed the water was all along the bottom. So I traced it around, and there was the outlet hose, lying on the ground, busily draining the water OUT. I put it back on, but the hose clamp needed a screwdriver to tighten. So I got DH out there to tighten it. No more leaks now!
So the moral of the story is: check your connections before the water gets that high and make sure they're TIGHT.
That is all.
That is all.
