We just put in a new pool with attached spillover spa. First time owners, so we are on a big learning curve. When the pump is off, the spa drains to pool level. Did some research on my own and learned this is likely a problem with the check valve. I called the contractor and he said that he never installs check valves on spas. I say, empty spa is ugly. His advise - just let the pool run all the time. Does his answer make any sense? Have you ever heard of a pool builder not installing a check valve o a spa? Would it be difficult to install a check valve now? How much should I expect to pay?
Also - thinking of getting a blower for the spa. Anything we should know or consider? Are these pricey to have installed?
