Check Flow Error / Red Light Blinking
qsch1
Hello, The annoying red light is blinking. Usually this stops after cleaning the filters or putting in the adequate chemicals ie salt. I checked all the filters (3 of them) and they are all clean. The tri flow sensor has been replaced about two years ago and the cell about two years. I noticed that the computer is reading 0 volts (11.4 amps) on the cell? May be the cable to the cell?Any help would be much appreciated. Thank you
Is this the Autopilot DIG 220 & PPC1 RC-35/22 Cell in your signature?
It is best to contact saltpoolguys for Autopilot problems…
Yes correct that’s it!
Thank you, it seems the Tri Sensor is bad. Can this be fixed or washed with an acid bath. A but surprised as only put it in about two years ago.
Nope, gotta replace it.
Reactions: qsch1
