No. Unfortunately my layout doesn’t allow for one.Do you plan on getting a solar reel as well?
Typically they only take a lot of hdpe, big ticket stuffOur recycling will not take it. Wrong type of plastic.
We prefer the thicker solar covers personally (granted we only have a 15' round. But our solar covers have lasted us 3yrs+ with multiple per week removals during swim season and using them as part of our winter closing routine.Several questions I'd like to put out there:
A. In an attempt to use the sun to heat and overnight retention as our heater gas line is down, I bought a 12 mil clear cover last year (Sun2Solar 1200 series). Is this the optimal approach? Id say our biggest issue is heat loss at night (days are in the 80's but nights usually mid 50's in SoCal, Agoura Hills). not looking for cheapest, but warmest waters as kids will get a-lot more use. I have a reel as well so the weight isn't a concern.
It's always better to cover as much as you can, but this may be a personal test & see if the difference is noticeable. If you were covering for cleanliness, that would be a definitely yes!B. Due to the odd shape, there are portions that remain uncovered, is it worth my time to "patch" those areas to get close to full coverage?
We prefer to NOT run at night (unless cooling the pool) as the water will "insulate" itself (not the technical term). Do run during the daylight/sun exposure to move (mix) the low, cooler waterC. optimal time to run the pump, i.e. does circulating the water when the sun is out vs at night induce better heat gain/retention?
We don't worry about the collection, but we also use our solar cover to keep our pool "clean"D. I have had issues with water pooling on cover when I deploy it, is it worth buying those grommets to drain out excess?
We go the thickest we can for lowest cost (kinda both worlds)What thickness/color is your cover?
I should buy a pool thermometer to track, any reccs?
here's a link for those drainage grommets: Quick Drain Grommet System - Set of 6 - SolarCovers.com
I have the same cover as you, a blue Sun2Solar 1200 series.What thickness/color is your cover?
I always did for both. I think it's impossible to get every bubble under and every drop on top, but i gave it a fair try with the brush.I forgot to ask as well, when putting out the cover, I usually get some large bubbles from trapped air, do you try to get the air out (I use my brush to attempt to get the air out as well as the pooled water on top)
Yep...just brush them out.I usually get some large bubbles from trapped air, do you try to get the air out (I use my brush to attempt to get the air out as well as the pooled water on top)
We leave it on whenever we aren't swimmingis it better to leave the cover on 24/7 when trying to heat and use the sun's rays? Or remove the cover during the day and only put it on at night
Anecdotal, but I find I get the best results when I leave it on.is it better to leave the cover on 24/7 when trying to heat and use the sun's rays? Or remove the cover during the day and only put it on at night
