I rented a house a month ago with an inground pool that has had issues but the owners don’t seem willing to help me. So I’m attempting to fix it myself and I’m hoping you guys can help me.
I noticed lately I have had to add the hose to top it off daily. I did a google search and learned about the bucket test to see if it’s evaporated or if there is a leak. I put water in the bucket and marked it and in 48 hours I’ve lost almost no water inside the bucket.
On the outside (pool water) I’ve lost lots.
In the picture the top line was 48 hours ago and the bottom line was 24 hours ago. So right now it looks like the loss of water has slowed down.
I should have mentioned I turned off the pump/filter at the start of this test and I put the plugs in both skimmers and both returns. The only thing not plugged is the two (I’m guessing they are vac holes) at the bottom of the pool floor.
At this point do i assume my leak is a crack that is either at the current water level or above it?
Here is a picture of the entire pool as of now.
If you can tell in picture the water level is low at the skimmer on the shallow end but on the skimmer on the deep end it is barely high enough to enter the skimmer. Looking around the rest of the pool walls I can see cracks but only paying attention to the ones that are now above the water line, this seems like the only one that stands out to me:
