I am new around here - and all the fine people of TFP have really helped my understanding of pool chemistry and got my pool in swimming shape (new pool owner this year).
I believe there is a need to replace my single speed pump and replace for a dual or VSP? With this being the case (at least to my understanding for energy efficiency guidelines etc) I am looking to replace the pump you see below. This pump currently is a horizontal output into the filter. Most of the dual or VS pumps have vertical. I find it hard to think I can easily plumb for this with the current pad in use. What are you guys thoughts? I say this because it looks to be like 2/3 90's to get where i need to be within less than 8" of space.
Another reason to replace the pump is that its frankly - NOISY! My neighbors have an above ground pool also - and their pump runs 24/7 and is lovely and quiet. I cautiously turn mine on to get the whole pool circulated once a day - trying to avoid times when they are on their deck or their yard (yes, it really is that loud - think of a very large AC unit). If i can reduce the volume (i can use it more and get a cleaner pool while also saving some money!).
As for a new pump, any suggestions? The current version of everything i have should be in my signature.
The second picture - is after the filter and prior to the heater. I have no way to bypass the heater. Should i install a shut off valve here with a bypass? I can imagine a time if the heater has an issue - i basically can't use the pool... thoughts? What is best practice here?
