Have a 22k gallon pool with Jandy CL460 Filter and Jandy Stealth SHPF 1.5 pump. The motor recently went out and I replaced with a Century HSQ220. Same THP as old motor.
Now upon startup the new motor cavitates around the lid for a couple seconds and shakes bad each time. Pump is bolted down and it doesn't help. There is a 2" PV coming in that is fed by 2 skimmers on 1.5" and one pool drain on 1.5". I have tightened unions and have a fairly new lid and the seal is lubed. Each start shakes surrounding plumbing and gets air into system.
