Changed fiber provider and now I can’t logic via screenlogic connect
ScoobyDue
1
Texas
Changed from Google fiber to AT&T fiber and added eero mesh wifi network and screen logic connect no longer connects locally and I can remember the password for remote connect. Tried hitting reset 3x quickly and it’s not working after 5 or so tries. What do I do?
Welcome to TFP.
Screenlogic does not play well with mesh networks.
The 3X reset for an IP address change is often flaky and hit or miss.
The most straightforward fix is install an old Linksys simple WiFI 2.4GHZ router as a wired device on your mesh network. Set the router IP range for your old network.
Basically present to Screenlogic a 2.4GHZ WIFI network like it had before.
Once you have it connected then you can tinker with changing the old router to bridge mode and trying to get the Screenlogic brick to switch IP to within your new address range.
