Hoping someone can shed some light on my issue,
The last few times I’ve tried to do my CH test I’m having a difficult time seeing the blue end point. Sometimes I think it’s there ,it’s very faint, sometimes the test goes clear without even seeing any hint of blue. I’ve researched on here and tried the few things I found. Adding 5 drops of r12 first, adding 8 drops of r11 and still get no clear cut blue. So my test numbers are all over the place.
So I tested my water at the hose bib to see if it’s my reagents and my CH test turned blue as can be. My tap CH is 100, I realize that seems low for AZ , I’m in Buckeye so maybe the water here is better.
FYI, My pool is about 2-1/2 yrs old. I’ve never done a water change.
I also have never had this problem until recently.
So I’m hoping someone can give me some recommendations as to where to go from here. I appreciate any and all suggestions.
