- May 19, 2011
- 66
- Vinyl
- Hayward Aqua Rite (T-15)
Here is a screenshot of my levels taken last night I have already added the proper amount of bleach to raise FC. I added the MA to lower PH and TA, I will be aerating the pool today with the fountain to raise ph to proper levels if needed. I added fresh water yesterday to refill splash out from the normal use of the pool but I can't seem to get the CH to drop to the recommended range seems like it always stays around that number 160 to 180...How do I fix this? Maybe the city water just has higher CH not sure. I also added more of the stabilizer to get me to 80 or should I just go with 70? What's your opinion? My salt shows 3200 to 3300 on the SWG and haven't added anymore cause I ran out of the proper reagents to properly test it so I'm running off of what the SWG is telling me... I haven't had a chance to update my Sig. so here are my specs... 24' round partially buried Wilbar Saltwater LX. 25ga Vinyl Liner. 1hp Hayward Power-Flo Matrix pump with 100lb Hayward sand filter <---(I know I should get bigger filter and I will be up grading) Hayward Aqua Trol SWG with Cell in Return Line no flow back required... 2" PVC with 1 1/2" reducers where needed 12" away from skimmer, Pump, Filter and Return.
