- Jun 18, 2023
- 10
- Fiberglass
- Hayward Aqua Rite (T-9)
I’m fairly new pool owner in southeastern NC. I have an older 10000 gallon fiberglass pool with SWG. My CH is testing really low. Initial test was 30. I double checked the test and I also tested my fill water. I’m on a well and it showed a CH of only 10ppm. Again, I double checked the test. Same result. From what I’m reading online, levels this low seem somewhat unlikely. Is this true?
I’m using a Taylor kit. I’m using the 25mL sample, adding the initial 20 drops and swirling, then adding the 5 indicator drops and swirling. Sample turns pink (not red). I then add the last chem one drop at a time swirling between each drop. It only takes one drop to turn fill water baby blue. The reagents have an exp date of 10/24.
I feel like I’m doing everything correctly. Likelihood that the low CH is correct?
