- Apr 16, 2019
- 2,010
- Vinyl
- Liquid Chlorine
Progress so far: pool almost full, added 2 1/4 qts of chlorine and 1 lb 5 oz CYA in a knee high hose. It's tied to the pole of my brush, which is the dinkiest brush you've ever seen! I'm supposed to be napping, and I've asked Mike to check the water about 3 pm and give the CYA a squeeze. Tested my other parameters, and here they are
FC 0
CC 0
pH 7.2
TA 20
CH 0
CYA 0
Like I said, I've dealt with the FC and CYA, will deal with everything else once those are balanced. I used the SLAM levels for FC because there's already leaf droppings in the pool, don't want it green. Gonna try to get that stuff out this evening, and hook up my Intex skimmer.
Question: do I have to add calcium increaser? It's a vinyl pool, so doesn't need it, but I don't know if it needs a baseline amt.
FC 0
CC 0
pH 7.2
TA 20
CH 0
CYA 0
