I have been following the TFP way for two (?) months or so and it’s made my pool gorgeous. We had a terrible startup on our black StoneScapes with the entire pool covered in calcium. Some areas were so caked on that it looked like elephant skin.
I’ve been battling it by keeping PH at 7.0-7.2 (usually 7.2) and occasionally letting it get to 7.4 or 7.6 but bringing it back down after a day or so. It’s been working and calcium comes of when I brush daily. Some areas have improved to where the black finish is back and other areas I can see black trying to peek through. The Abolone shell is starting to pop out again as well.
My concern now is I tested this morning and the CH is at 450, up from last week and the week prior. My husband has been trying to pressure wash calcium off but I think that may have caused the CH to rise. Our fill water is 150. I thought I may have been seeing things this morning but I am sure the scale in areas it was improving or gone is starting to building up again like the steps and tanning shelf. I can see a haze where there wasn’t anymore scale. I watch this pool like a hawk so I’m sensitive to changes.
Per the Stonescapes guidelines I should be at no more than 400 so I believe my high CH is contributing to the calcium haze I’m seeing on the pebble again.
Do you suggest a partial drain and refill? I have an auto refill. I’m not sure how much to drain if so. I’d prefer not to but if the CH is the issue we may have to.
I did a full work up this morning.
Temp: 77
FC: 6.5 (added 1 cup bleach)
PH: 7.4 (added 1 cup muriatic acid)
TA: 60 (added 2lbs baking soda)
CH: 450
CYA: 60
CSI: -0.31
I test FC and PH daily and do a full panel weekly.
Thanks! I wouldn’t be too concerned if that scale wasn’t taunting me. CSI is good.
Temp: 77
CH: 450
CYA: 60
CSI: -0.31
