I have a EVQ225 motor that I'm connecting to a Jandy Aqualink RS-8 Combo, REVT.2. The motor works as designed if it's not connected to the Aqualink. I followed the directions in the Century manual to use Century Connect. I placed both dip switches on the motor (#3 & 4) in the On position. I powered the pump on (without it being connected to the Aqualink). Then i powered the pump and the Aqualink down. Connected them via the RS485 connection. I double checked the wiring connections on both ends. I also ensured I followed the wiring diagram meaning red to red, black to black, etc. The only dipswitch on the Aqualink panel set to On is dipswitch 1. If I use the Aqulink to turn on the pump, the green light on the pump motor comes on but the motor never starts. Also, when I go into the iAqualink dashboard setting to configure the pump I don't see the motor as an option in the variable speed settings and I only see the iAqualink WiFi4 in the RS485 Devices view (in the help menu)
I've spent 3 hours searching the forums and the internet but I can't find any solutions. Does anyone have any insights or solutions? I've attached the relevant manuals. thx
