Thank you. I re-read the manual carefully and that is spot on. What i called backwashing, heyward calls cleaning. Same thing. I guess if the bumping is supposed to alleviate the de from the fingers and it can all simply gravity drain out, then you can assume to add as much de as when you started the filter(precoat pressure). I have read that, after a backwash, some medium stays in the fingers of the filter and only to add some or most of the medium back in. I guess the bottom line is to judge it by the psi reading when re-filling until you reach the precoat pressure, whatever amount of scoops or lbs it ends up to be. I’ve put in about 3 scoops as compared to 5(starting) and its been good so far. I guess that tells me that not everything has truly drained out.
