It's early in the season, but I'm already seeing algae. Water temp has been hoverning around 60, up a bit and down a bit. So I started up the salt system and have been trying to get it going. Not working. So here's what I'm seeing:
11,000 gal pool with Aquarite salt system, T-15.
1. Water temp today is 64 degrees F.
2. Salt system was off, as I slammed my 11,000 gal pool with 1 gal of 10% chlorine, filled the chlorinator with 3"tabs, and filled a floater with 3" tabs. Chlorine is around 10 right now.
3. I tested the water with my Taylor FAS-DPD kit. Free chlorine = 10ppm. Ph is 8.0 TA is 130. Hardness 200. Salt 3200.
4. I double checked with test strips, and all were pretty close to the real readings from my Taylor kit, so chemicals are ok.
5. It turned on the salt system with the pump already running. clicked 5 times to calibrate the salt level. It started high, but dropped for about a minute. Salt level showing on the system is 2200. Showing on and Generating.
6. 5 minutes later, it's still showing 2200, but "Check Salt" red light is on, and yellow "check Cell" is on.
7. Oh, and I cleaned the cell with water/acid yesterday. No visible buildup anyway, and when I added the solution no foaming reaction. So the cell was clean.
So, I'm afraid this 2 year old cell is dead. But if anyone thinks something different (and cheaper) I am all ears!
Thanks all.
Steve
Thanks all.
Steve
