I am just starting out reading TFP, my concern it the FAS-DPD test for CC. I think of getting the TF100 kit. Here are the directions I found elsewhere on TFP:
MY question concerns that in parenthesis at the end of step 3. If it turns pink again (end of step 3), how you suppose to continue to step 4, because its now already pink? I mean step 4 sounds like it assumes sample does NOT turn pink at the end of step 3.
Is there another more accurate CC test? I mean you are suppose to SLAM if CC>.5, and this means just one drop in step 4.
FAS/DPD Chlorine Test
separately measures FC/CC.- Rinse and fill sample tube to 10ml mark.
- Use teeny blue scooper (hold the flat end) to put one heaping scoop R-0870 powder into sample, swirl to mix. (OK if not all dissolves.) Sample should turn pink. If it "flashes" pink then the pink disappears, add more R-0870. If there's never a hint of pink at all, skip step 3; FC=0.
- Add R-0871 one drop at a time, swirling the sample continuously, 1-2 sec between drops. Stop when sample turns colorless. Multiply #drops by 0.5 to get FC. (If it turns pink again after a few seconds, don't worry about it.)
- Add 5 drops R-0003, swirl to mix. If it remains colorless, CC=0. If it turns pink, again add drops of R-0871 (swirling continuously) until it turns colorless. Multiply drops by 0.5 to get CC.
