Can't do. Fixed.speed :/I hear a very small suction leak (air) on high speed.
I think I would "fix" it by reducing pump speed until bubbles stop and make that my "new" high speed.
Yes it doesWhen you shut off the pump, does the filter gauge go to zero?
Do you have a suction gauge you can put on the pump basket drain plug?
Removing the wet end from the motor should be fairly straight forward:
Not much success :/You might just try lubing both the pump lid and drain plug gaskets. I know you said you did not see any air but when it enters the pump basket at the bottom, you may not see it.
50/50 is actually both valves fully open. But they both go through an single exit hole to the pump as big as each port itself.Can you just open the valves 100% to both ports so there is no restriction at all?
