jedigrover
- Sep 13, 2010
- 333
- Plaster
- Hayward Aqua Rite (T-15)
It seems like that gas line must be newer than that though, since it's the yellow poly stuff--that really started coming in vogue in the mid 90's. I had my yard line replaced in 2004 and that was the first I'd seen anybody run it. In 2011, I had a smaller run done for a grill and the company opted to go with black iron, wrapped with the plastic barrier stuff instead of springing for the poly (they should've just gone with the poly--it would have saved them money in the long run as they failed inspection 3x with all their attempts to cut corners).
My guess would be there is a reason the line has been replaced. Have you dug it all up and found out if the whole run was done with poly, or could it still be iron pipe part of the way?
