I have a sand filter that is leaking and not cost effective to repair. So I need to replace it. However, it is very low maintenance. All I have needed to do is:
I am considering replacing it with a cartridge or DE filter. Having read all that I can on it here and elsewhere, here is what I know:
Cartridge Filter:
DE Filter:
Here is my impression and please correct me if I am wrong.
1. It seems like it takes longest and most work to clean a cartridge filter each time you do it. I mean you have to remove the cartridges, hose them down thoroughly, and re-install them. However, perhaps you don't have to do it as often as a sand or DE filter?
2. Backwashing a DE filter is like backwashing a sand filter but you have to also replenish the DE and is done about as often. So its a bit more work and cost.
For those who have experience and own cartridge and DE with a decent size pool 15k+, how would you compare the cost and maintenance effort of the two?
- Backwash every few weeks (takes like 10 minutes each time)
- Replace sand every few years (only done once, had to hire someone to do it for a few hundred dollars)
Cartridge Filter:
- Remove cartridges every few weeks, wash off, re-install (takes like 1 hour each time so much more work than backwashing sand).
- Replace cartridges every few years (costs a few hundred dollars but cheaper than replacing sand, I think)
DE Filter:
- Backwash every few weeks but need to replace DE each time. So it takes longer than sand backwashing (20 minutes?) Also I think it costs like $7 to replenish DE each time?
- Clean "grids" once or twice a year. Can usually just pay someone to do it for like $120.
- Replace "grids" every few years. (cost?)
