I put in a new pump last year after 9 years of use. The pump is a Waterway Hi Flo 1.5 Hp 2 speed pump, basically the same pump I had before, although it seems to be a little stronger than it's predecessor. The pool is a 21' X 43' X 54" AG with a Millennium Cartridge Filter System from Waterway and I have never had a leak problem before but after a few months with the new pump and after cleaning the filter about 3-5 times, it developed a leak in the filter around the ring that connects the top and bottom of the filter, especially right at the spot where the snaps end up. It is a steady leak, sometimes nearly a stream coming from 2-3 spots that leaves a puddle after a short time. If I flip the pump down to low speed, it stops, but low speed doesn't do a good enough job of cleaning the pool. There are times, after cleaning the filter, that it will not leak for several days. But if I turn it off for any reason, nearly 100% of the time, the leak will start and will continue until the next time I clean it. I always lube the large O-ring around the filter after cleaning and even bought a second O-ring and I get the same result. Presently, the pump is running 19 PSI on High and 5 PSI on Low. Is there anyway that I can stop this leak? I really need to run the pump on the high setting.
