Carbonate Alkalinity
MA5177
216
Phoenix, AZ
CircuPool RJ-45
I’m starting up a freshly plastered pool, and the instructions on day 4 say to test my CARBONATE alkalinity. What is that? How do I test that with my TF kit?
It’s a fancy way of saying to test your calcium hardness (CH). Too little and the water will suck it from the plaster. Too much and you will get Calcium scale on the finish and inside the plumbing/equipment.
Amazon sells it in bulk. You want pure Calcium Chloride with no additives
See Recommended Levels and download the poolmath app for free to figure out how much you’ll need based on your TF-100 results.
Ok it threw me for a loop because it said to test for that then it says to test for CH
I have the pool math app, but trying to follow the builders guidelines from the national plaster council
Carbonate alkalinity is the adjusted alkalinity as described in the TA page.
Calcium hardness is not the same thing as carbonate alkalinity.
Just try to keep the CSI between -0.3 and 0.0.
Reactions: MA5177
My bad. Google said that’s how it was tested.
*edit. Ahem. Excuse me. Google put me in touch with THREE blog sites that even though they agreed, I knew better than to trust, not being here.
Reactions: JamesW
This is the guidelines they recommended, anything different I should do this is freshly plastered a couple days ago.
As of this morning my Ak was 120 and PH was about 7.6 so I added more acid. CH was 250
No chlorine or CYA added yet
Calcium hardness and total alkalinity are both reported in units of "calcium carbonate" equivalent.
So, that can create some confusion.
For example, if you added calcium carbonate to the pool, the calcium hardness and the total alkalinity would go up by the same amount.
My pool is 3 days old plaster and I’m having trouble getting the alkalinity down to 80, currently about 110. I’ve been adding acid every day to get the PH down but it’s not working very well. Any suggestions? How much can I add at once? 13,500 gallon pool.
When your pH tests at 7.8 or higher, lower it to 7.4 or so. This will be a common occurrence (daily) at the start up of new plaster.
TA will take care of itself.
Reactions: MA5177
Are you using pool math to do the calculations for how much acid to use?
Also, use poolmath to calculate the CSI.
Reactions: MA5177
Mostly just brush daily and maintain the CSI between -0.3 and
Yes pool math... for AK all it says is “lower PH to 7.0-7.2
Correct, just keep adding the correct amount of acid to lower the pH and the TA will be fine.
What is the current CSI?
As long as the CSI is not over 0.2, there's no rush to lower the TA.
If the pH is in the 7.2 to 7.4 range, the CSI should be good.
Reactions: MA5177
Ok thanks, as of last night these were my readings
