The pool is coming up on two months old. My numbers at 4:45 pm tonight were FC 3.5, TC 3.5, pH 7.85, TA 90, CYA 70. Still using CH of 210 from a couple of days ago. My CSI is +.23. I have read on TFP that a lower TA would mean less daily pH rise. Last night at 6:30pm, the pH was 7.48 a few hours after adding 42 oz of acid. I added another 24 oz of acid tonight to get the pH down a bit. I will add liquid chlorine around dark.
What do I do about the TA and carbonate alkalinity since it is on the low side as per the Pebble Tech "ongoing maintenance ranges"? The Pebble Tech guidance does say you can be outside of the listed ranges if the LSI is -.3 to +.3. But, the listed range for ongoing maintenance (after 28 days) is a carbonate alkalinity of 80 to 100 ppm, not total alkalinity. With my CYA of 70 and pH of 7.85, the calculated carbonate alkalinity is about 65 ppm. Do I need to get the TA up to have a higher carbonate alkalinity, or let if fall or keep TA around 80 and hope I can get by adding less acid?
Pool Math shows a CSI of -.04 with pH of 7.6, and TA of 85, at 91F. That is what I expect it to be after the 24 oz of acid gets mixed in now. The water is still extremely clear.
My TA had been about 110 until adding 106 oz of acid over the last three nights.
