I'm having a hard time getting my PH down:
On Saturday morning, my FC was 3, TH was 65 and my CYA was 65, and my PH was 7.7, Salt 3300 I planned to add Borax to the pool this weekend. So I put in some stabilizer, and adjusted my SWG to bump up my FC a little on Saturday, and I put in a full gallon of Muriatic Acid (Klean Green) to lower the PH in preparation for Borates on Sunday. I couldn't get a baume rating on the Klean Green Acid, so I put a little extra from the recommended dosing) to lower the PH down.
Over the course of the day I measured PH and it dropped down to 7.4, and I started adding Borax 20 Mule. I alternated 10 lbs of borax and half a gallon of muriatic acid every couple of hours. Ultimately, I ended up putting 40 lbs of borax and 2 gallons of muriatic acid in the pool throughout the evening. Checked the pool this morning and the pool was up to 8.2 again. So I added a half a gallon of muriatic acid this morning.
Here are this evening's readings:
FC = 5
CC = 0
PH 8.2
TA = 70
CYA = 70
Salt = 3300
PH seems to have stayed the same after running the filter from 8 to 6 (should have circulated all the acid and water in that time?). So I just added another half gallon of muriatic acid. Any ideas on why the PH is still high? Is it just the borax keeping it up and I need a little more acid to knock it down some?
FC = 5
CC = 0
PH 8.2
TA = 70
CYA = 70
Salt = 3300
