Can't remove drain plug from heater, am I safe?
joeypools
In The Industry
Nov 1, 2018
6
Boston
I'm not exactly sure what type of heater this was (I think Pentair natural gas), but I could not get this drain plug out for the life of me. It's a metal bolt. I soaked it with PB blast to try to loosen it but it only continued to strip. I blew the water out of the heater with a Cyclone. I also filled up the heater with antifreeze. Do you think I am safe leaving this plug in? I really don't know what other options I have but to try to drill and extract but don't want to if not necessary. See photo. Thanks!
I would do your best to get it out and let any residual water drain out. I found out the hard way.......... any water in there will freeze and expand and have no problem cracking those cast iron heat exchanger manifolds!
