Hello! I've had a salt pool (vynil lined) for a year now. We always had trouble with lower pH around 6.9, but otherwise we had no issues. We kind of neglected the pool during 6 weeks last winter and the water turned green. The pump wasn't enough to clear it so we added some chlorine. After that the pH started going completely crazy, pH ranging from 3 to 10, and we called the pool store. They came, said the alkalinity was low and corrected it. But since then (November) alkalinity is ALWAYS low. We've already added 20 kg (44 lbs) of baking soda and alkalinity always ends up between 10 and 40. We've been adding half of what's needed according to the calculators, stopping the pH dosification, and adding the rest after a couple of days, but it only goes to 60 or 70 and then it lowers again. I found a different formula that tells the maximum amount of product to add, so now I'm adding 200-400 mg daily and I still can't get the alkalinity above 70 ppm several hours after adding baking soda, 30 the next day. Is a 31 m2 pool and it's covered. Water temperature is between 23 and 30 C°. I'm very tired of having to add baking soda everyday and the alkalinity is always low, the pH is always crazy. What am I doing wrong? I'm desperate.
