I finally got my TF100 kit and have been doing tests over the past couple of days trying to get my TA down. I think I've got that under control, but I can't seem to keep any chlorine in the pool at all. I added 2lbs of shock yesterday (Clorox 6 in 1 dichlor) and the chlorine levels spiked as expected (to 2.5 FC). Today, I'm back to barely 0.5. Logic would tell me that the chlorine is being eaten alive by the sun. I have an inline chlorinator but I don't have any pucks in there since my CYA is fairly high and I don't want to keep adding to the problem. That being said, I also know that also defeats the purpose of having an inline chlorinator and is also a contributor to not being able to keep chlorine in the pool.
So here are my questions:
For context, my water is crystal clear and blue. My test readings from this afternoon are:
- How do you guys feel about the pucks? Some say don't use them and just sprinkle a little bleach in once in a while, others swear by the pucks.
- Are there any pucks that don't also have CYA in them?
- Should I just forego the chlorinator and get a floater?
- If you do use a chlorinator, how many pucks do you put in at a time?
- FC - 0.5
- CC - 0.5
- pH - 7.6 (just added MA per PoolMath to try to reduce TA, so this will be lower on the next test)
- TA - 180 (down from 240 a week and a half ago)
- CYA - 100
- CH - 1,425 (good lord! the pool needs to be resurfaced, so I think that's why this is so high...right?....or am I totally way off?)
