We cannot hold chlorine in our 2-month old pool. We will boost the chlorine content up with stabilized dy-chlor (or shock, if the free chlorine doesn’t match), but over the course of a couple days, both the total and free chlorine will gradually decline to zero.
Our chlorinator (set on the highest setting of “5”) goes through about 1 tablet per week (I keep it full, and add a tablet if there is room). I hear others say they hold the chlorine level by adjusting that chlorinator setting….but even wide open, we don’t seem to get enough chlorine input.
I don’t think this is a total vs free chlorine problem, as we have good luck shocking the pool when those two separate (e.g. after we have a bunch of kids swimming), and total/free chlorine come back to equal (and then will decline together over the next couple days).
What do you think might be our problem? Or what would you recommend trying??
Recent chemistry (from Leslie’s)
pH 7.6
Alk 104
CyA 31
FAC 1.0
TAC 1.0
CH 380
TDS 800
Pho 242
FE 0
CU 0
Pool/equipment
In-ground, concrete pool + hot tub
18,000 gallons
Filter vessel
Chlorinator: Pentair 320 automatic in-line chlorine/bromine feeder
Ozone system
Pump 10 hours/day x 3200 RPM
Chemicals
Shock: Leslie’s Power Powder Plus 73
Chlorinator: Regal Chlorinated Tablets 3” (Trichloro-s-triazinetrione)
Chlorine granules: Regal Dy-chlor II (Sodium dichloro-s-triazinetrione dihydrate)
Acid: Muriatic Acid 20 Baume Hydrochloric Acid 31.45%
pH 7.6
Alk 104
CyA 31
FAC 1.0
TAC 1.0
CH 380
TDS 800
Pho 242
FE 0
CU 0
Pool/equipment
18,000 gallons
Filter vessel
Ozone system
Chemicals
