Can’t get rid of what looks like sand at bottom of pool
Yes, get the good test kit.
If the "sand" poofs up into clouds when disturbed - it is dead algae. Currently you likely are growing more, so an endless cycle of filtering it out, and then more replacing it.
Do as Texas Splash advised right now. When your kit arrives, the critical numbers will be the CYA (stabilizer), Free Chlorine, and Combined Chlorine. For the Cl, use the test involving powders and drops.
Visit your local WalMart and get several gallons of Pool Essentials liquid chlorine. Once we know the numbers, we can guide you on how much to add, and how often to test, to permanently knock it all down. It will be a sustained effort, not a one time event. Read up on the SLAM method in the Pool School here.
Here are the number with the test kit suggested by Texas splash
Cya 70 ppm
Fc 9 ppm
Cc .2 ppm
Ph 7.6
Calcium hardness 260
Total alkalinity 275
Glad to see you got a good test kit. :goodjob: I think now would be a good time to do anOvernight Chlorine Loss Test. This is a good test to see if you have algae brewing. Your TA is a bit high, but let's focus on water clarity and making sure you don't have algae before addressing the TA.
Reactions: kvazquez2006
Better get 1 1/2 quarts of liquid added right now.....you need to be in the 8-10 ppm range. (5 is bare minimum, 8-10 gives you some buffer for what burns off later in the sun).
