Hi, I am new to pool maintenance. Waiting On test kit to arrive. However, despite putting tons of chlorine in pool the algae will not die and free chlorine is 0. Any thoughts on what I’m doing wrong?? The circulation system works.
Thank you!First off welcome!
Without the test results its hard to say what is wrong. While waiting for the test kit add 5ppm of chlorine each day to keep from getting much worse.
Your helper has the right idea with the net/vac. See what you can get up from the bottom. Less organics in the pool will help once you get your test kit.
Once you get your kit post full set of results and we will help you out with next steps.
Also if you haven't read up on the following take a look now so you can hit the ground running when you get the test kit.
SLAM Process
ABCs of Pool Water Chemistry
pH is right where you need it for the slamReceived my test kit! Starting to feel like there is hope… here’s where we’re at:
pH=7.2
FC=1ppm
CC=1.5ppm
CH=575
TA=150
CYA=22
Any thoughts on where to go from here (especially order of adding chemicals/tips on best practices of doing so) would be GREATLY appreciated, by both me and my twin 5yos who desperately want to swim
Thanks in advance!
Emily
Hmm not really sure about the white powder hopefully someone else will help you get to an answer there.Thanks for asking! We got rid of the green, but it continues to be cloudy. I posted a separate thread about how I added the recommended amount of stabilizer in the recommended method, but it seems like it didn’t dissolve. There is fine, super find white dust in the water, And when I vacuum it gets picked up from the bottom of the pool, and when I just backwashed it came out all over the sidewalk. Then I just tested my CYA and it’s at affectively zero. So confused, and running out of money buying so much liquid chlorine I can’t keep up!
