Ok so it has been a couple of weeks my pool is green. But water is actually clear looking when backwashing etc.
I have tried everything logical to get it back clean looking.
I have a 16,000 liter vinyl liner Intex pool
My pool started going green so I tried to slam it over 3 days using stabilized chlorine granules, it was not getting better so I went to the pool place to get water tested.
Results Chlorine 20ppm PH 7.4 Alkalinity 133 Cyanuric 143 Copper .3 Phosphate 290
I was told problem was my Cyanuric to high and this might be causing issues. I arranged to come back a few days later and retest. In the meantime I had actually ordered stuff to upgrade the pool including a proper skimmer and new pump and filter.
I installed the skimmer and the new 3000 gallon an hour sand filter which I filled with course and fine glass and topped up the water with several thousand litres of new fresh water and got it retested water was still green
second test four days later Chlorine .42ppm PH 7.9 Alkalinity 90 Cyanuric 5ppm Copper.3 Phosphate 0
The pool shop recommended I try liquid chlorine instead of the Stabilised chlorine so I went home and added 3 litres of liquid chlorine and let the pump run for 24 hours but still no change next day I added another litre of liquid chlorine and still no change still light green.
Third water test Chlorine 24.97ppm PH 7.4 Alkalinity 121 Cyanuric 148ppm??? Copper .10ppm Phosphate 297ppm
I could not understand this test how had my cyanuric gone from 5ppm on the second test to 148ppm on third when I had only added liquid chlorine which has no stabilizer?
I am at a loss as to what to do. Its been slammed multiple times, Replaced a lot of fresh water and new pump and filter but it is still green looking.
If you got this far thanks for reading my rant and if you have any ideas let me know.
